Inatke manifold Help!!
I want to swap the stock intake manifold on my d16 for the manifold pictured and
I was wondering how easy this will be and what additional parts i will need
Thanks in advance, i really appreicate it
H-T Poker champion
Re: Inatke manifold Help!! (RugerRell)
You'll need a new gasket.. Everything else you should be able to salvage from the current intake manifold I would assume.
Is that an OEM intake manifold? If so, then you'll just need a new intake manifold gasket. If not, you may need some other stuff.
Changing intake manifolds is not the easiest job, from what I've seen.
Re: Inatke manifold Help!! (Hybrid-Fusion)
Yeah, I have the d16y7 and want to swap to the d16y8 intake manifold because it flows better and it will allow me to put in a strut bar in
Bense
11-09-2005 05:16 PM
