00 ek lower rear control arm bushing part number, help please (pictures inside)
Old 01-05-2007, 05:41 PM
vtec4lyfe's Avatar
Default 00 ek lower rear control arm bushing part number, help please (pictures inside)
Alright i was installing the coilovers on my car and when undoing some of the lower rear control arms bolts i snapped one inside of the control arm in the bushing. Now am i able to purchase the bushing at honda and if so what are the part numbers? What are my other options? with a set of aftermarket lower control arms do i use the oem control arm bushings? Some one please help me out, its highly apreciated
This is the control arm bushing with the bolt seized and snapped inside. I have removed the bushing from the control arm and have retrofitted my own bushing for the time being. This is the part i am looking to get, thanks!
Old 01-05-2007, 05:58 PM
BlueIntegraBoy's Avatar
Default Re: 00 ek lower rear control arm bushing part number, help please (vtec4lyfe)
You can order aftermarket LCAs and don't have to worry about replacing the bushings. Or you can order the Energy Suspension kit to replace the OEM bushings on the LCA.
http://www.slhondaparts.com/im...2.jpg
#13 - 52622-SH3-013 BUSH, RR. SHOCK ABSORBER (LOWER)
Other bushing that connects the LCA to subframe and to trailing arm... 52365-SH3-000 BUSH, RR. ARM (LOWER) (YAMASHITA)
Old 01-05-2007, 06:38 PM
vtec4lyfe's Avatar
^ thanks you for your helps with my decisions and options, i will be ordering aftermarket LCA's tonight.
Old 01-05-2007, 07:31 PM
EK FLY's Avatar
Default Re: (vtec4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe &raquo;</TD></TR><TR><TD CLASS="quote">^ thanks you for your helps with my decisions and options, i will be ordering aftermarket LCA's tonight.</TD></TR></TABLE>
that was better , for the price some shops will charge u could buy some nice set of aftermarket lca's , word of advice , i would go with the bling bling factor
Old 01-05-2007, 08:33 PM
MasterKwan's Avatar
Default Re: (super-hatch)
You can buy the bushings from King Motorsports too but, new LCA's are only $100 from Honda (Majestic)
Old 01-06-2007, 12:22 AM
Default Re: (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">You can buy the bushings from King Motorsports too but, new LCA's are only $100 from Honda (Majestic)</TD></TR></TABLE>
And so are aftermarket LCAs, plus with the aftermarket ones he can later add a sway bar.
Old 01-06-2007, 01:22 AM
chrisw85's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">And so are aftermarket LCAs, plus with the aftermarket ones he can later add a sway bar.</TD></TR></TABLE>
I thought all 96-00 civic rear lca have the hole for the endlinks?
92-95 civics, you need either civic ex abs sedan lower control arms, or 94-01 intergra arms.
Old 01-06-2007, 09:33 AM
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">
92-95 civics, you need either civic ex abs sedan lower control arms, or 94-01 intergra arms.</TD></TR></TABLE>
My bad, they do. I was thinking 92-95 Civic. Yeah, just get aftermarkets for the same price as OEM for the bling factor.
decode33
Honda CR-V & Element
10-29-2011 06:48 AM
Furious Styles
04-26-2011 02:16 PM
Stadler
07-26-2008 01:52 PM
94vtirozguy
04-14-2006 11:37 PM
PaulB
05-03-2004 05:36 AM
Quick Reply: 00 ek lower rear control arm bushing part number, help please (pictures inside)
