EG Motor Swap Tool List???
hey guys, im pulling out a blown d16 and swapping in a jdm D15B.. all of my tools are packed up in storage.. anyone have a list of the tools needed for a swap.. i know there arent but so many sizes used in the engine bay..
thanks in advance..
thanks in advance..
Re: EG Motor Swap Tool List??? (boostedsingle)
hear a list to start
Engine hoist
you need a scoket set that had short and deep socket in 1/4 3/8 1/2
10, 12, 13, 14, 17, 19
you going to need a 32mm axle nut socket.
a pitman arm puller will help you get the ball joints out
ever kind of pliers you can get your hand on
you can never have too much tools
Engine hoist
10
12
14
17
19
32 for the axle nut
try to get some short, deep, 1/4, 3/8, 1/2 inch ones, extensions, reducers, swivel joints, and wrenches too in all those sizes if possible, and of course you need the ratchets that the sockets go onto
some pliers needle nose and whatever else kind of plier you can find
some crescent wrenches, those adjustable ones
couple of screwdrivers phillips and flats
a pry bar for removing the axles and whatever else wont come loose
a big bar or a breaker bar for the stubborn nuts
some PB blaster for the stubborn nuts
some punches for the shift linkage pin and the axle nut where it is pinched in
a cherry picker, OR 2 Jacks if you pulling it out from under the car
ball joint seperator
big effin hammer
maybe some unusual tools like vicegrips etc.
that should be it
12
14
17
19
32 for the axle nut
big effin hammer
that should be it
Re: EG Motor Swap Tool List??? (gezzuzz)
which socket sizes will in need in 12pt.. we are doing both a clutch and flywheel while the motor is out of the car..
Re: EG Motor Swap Tool List??? (richard7968)
Punch for the bitch pin. Also you don't NEED to separate the balljoint. Sometimes it's easier to disconnect the upper control arm from the strut tower and unbolt the strut from the lower control arm to pull the axle out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedsingle »</TD></TR><TR><TD CLASS="quote">which socket sizes will in need in 12pt.. we are doing both a clutch and flywheel while the motor is out of the car..</TD></TR></TABLE>
12pt 17mm 1/2 socket for the flywheel
12pt 12mm 3/8 socket for the clutchplate
DRKSol
35
03-21-2004 05:11 PM
emr88
32
05-23-2003 06:57 AM
