Rear Lower Control Arm Mount Replacement
I'm looking at a project Del Sol that has had the rear lower control arm mount cup off. How bad would this be to replace? Can you buy this part from Honda or do I need to go junk yard hunting?
Re: Rear Lower Control Arm Mount Replacement (TwoKSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwoKSiR »</TD></TR><TR><TD CLASS="quote">I'm looking at a project Del Sol that has had the rear lower control arm mount cup off. How bad would this be to replace? Can you buy this part from Honda or do I need to go junk yard hunting?</TD></TR></TABLE>
It depends how it was cut off. I don't know if it can be gotten from Honda or not. The hard part is making sure it's in the right spot. Then tack it and measure it to see if it's in the right place then seam weld it to be sure.
Del Sol on Steroids
12-26-2007 11:27 AM
