first start fails. second start OK...
Hi all. obviously new here but have a long history on the protege forums and various other car boards. I've searched... I can't find this anywhere.
My '96 LX 1.6 sohc is having a strange problem. Like me, it seems it doesn't want to go to work. First thing in the morning it turns over fine, but doesn't start. So I take my truck to work. When I get home and turn the key, it starts totally fine just it should. This happens most mornings but not all. When it does start and I take it to work, it starts fine at the end of the work day. Once it starts, there is no lack of power (well, there's ALWAYS a lack of power ), no hesitation, no stumbling..
Cap and rotor, plugs, wires are less than a year old. I've checked electrical connections and put electrical cleaner on most of them.
Any ideas? Thank you!
Re: first start fails. second start OK...
It might be the starter or distributor? Having problems getting spark in the distributor was one of my car problems and it would shut down my car while driving. Or simply the starter...
CEL codes?
When the engine won't start, listen for whether the fuel pump primes and watch for whether the CEL stays on steady. Also check for bright white spark at the four plugs.
no CEL light, but I haven't read the codes. Perhaps there are codes stored that don't turn on the light... Hard to hear fuel pump - My street is noisy and there's never a whine from it even when it starts fine. I should probably pull the back seat so I can hear better.
CEL is on steady when not starting. Normally when it doesn't start I'm trying to get to work and don't have luxury of time to pull the plugs and check for spark... If it fails on the weekend I'll have an opportunity.
I did read elsewhere that turning the key a few times prior to starting helps prime the system. (i think what I read said it could be pressure drop due to very slight injector leak and this helps overcome it - is that true?) I did it this morning and the car started. But I don't know if I've found a temporary work-around or if it would have started anyhow...
I've never had the car shut down while driving and it turns over fine - just doesn't start - so I kinda doubt it's starter related, and never had any issue once the car is running so dizzy would surprise me. At this point I'm much more looking at spark or fuel - will investigate and post back.
thanks for your help so far.
Fish Twig
I suppose. I was answering RonJ's questions in the order they were asked. To clarify and eliminate any other confusion:
1) No there is no CEL under normal operating conditions when car is running after it has started.
2) But CEL is on solid when trying to start (as most dash lights and warning lights normally are).
Originally Posted by RonJ
CEL codes?
CEL comes on solid when key goes from off to II, then turns off after 2-3 seconds (normal timing) at the same time there is a "click" from the engine - sounds like a relay click. Has occurred every time I've started over the past couple of days when I've actually been paying attention, and is consistent with every car I've owned.
Fuel pump seems to prime every time - seems to run the same amount of time each time key is turned, maybe 1 second or so (makes me think it's on a timer, not based on fuel system pressure?)
Failed start when turning key from off to start immediately this morning without time to finish priming the first time. Waited 5 minutes, turned the key 3 times to on without starting, let the pump prime, and then she started fine...
That's what happened this morning - when I first tried to start, it turned over but wouldn't catch.
Sorry I did turn the key this morning again right after no start - sounded like the fuel pump primed and CEL was on for normal duration. wouldn't start again. ... then I waited and 5 minutes later all was good.
sorry my earlier post wasn't entirely clear what happened. I think I was still asleep.
I've learned to keep the key into the 2nd position for about 4 seconds before moving to 3rd position, This seems to give enough to time to "prime" it (although it shouldn't need it as there isn't a carburetor). I don't question it... as long as it works.
4drint3gr4
11-29-2009 10:13 PM
Mojo-Jojo
02-03-2004 08:16 AM
