jdm d15b vtec crankshaft - What engines have same crankshaft?
I need a jdm d15b vtec crankshaft. I wanna know if any other engine has the same crankshaft.....Thank you
re: jdm d15b vtec crankshaft - What engines have same crankshaft?
Do you have a bad one you can measure the mains on?
If the mains are also 45mm like the rod journals then all the D15B2/7/8 cranks are the same size as the D15B.
The other part I would question is do the journals have 1 or 2 oil holes per journal?
I'm assuming you have a bent crank or some other problem with the d15b crank causing you to need a replacement.
