92-00 Idle, what all can affect it.
Hysterically Calm
Hi all,
I've seen all kinds of idle things for out cars, the two most usual suspects are the IACV (all years 92-00) and the FITV (92-95).
However, every so often I seen other things suggested such as Coolant Temperature Sensor.
This got me to thinking, I don't even remotely know what all can affect idle on our Hondas.
I'd like to create a list of everything that can affect the idle of the car. Including to the uncommon ones and I'll make sure they go last on the list.
So here are the ones mentioned in this thread:
1)IACV - Idle Air Control Valve
2)Intake, Intake Manifold and Vacuum Leaks
3)Maladjusted Idle Screw
4)FITV (92-95 only) - Fast Idle Thermo Valve (I think the IACV will compensate some when this first starts acting up)
5)ECT - Engine Coolant Temperature sensor
6)TPS - Throttle Position Sensor
7)PCV Valve (92-95 typically) - Positive Crankcase Ventilation valve
8)Ignition/Mechanical Timing errors.
What else can cause idle problems with our 92-00 civics/del sols?
Oh, and I did look in the FAQ and for idle it only talks about the Set Idle Procedure, the IACV and the FITV. It doesn't even mention the ECT or anything else that maybe brought to light in this thread.
Last edited by TomCat39; 05-28-2015 at 06:34 PM. Reason: Updating post to include all knowledgeable input.
Hysterically Calm
Re: 92-00 Idle, what all can affect it.
PCV Valve won't affect idle on 96-00?
Hysterically Calm
Sounds good, can the Intake Air Temperature Sensor (IAT) affect idle?
And what about the Manifold Absolute Pressure (MAP) sensor?
Generally not.
Yes, but only indirectly by affecting engine performance. When you have MAP sensor problems, idle issues are generally the least of your problems.
Agreed, but again indirectly through general engine performance and not specific to idle system.
True, but for an idle specific issue, it's an ECU (no idle up) rather than A/C problem.
When the A/C system itself causes idle problems, it's due to increased engine load (over-pressurized system or locked compressor).
ac system?
Hysterically Calm
When the engine is cold, the engine idle speed is high. This happens because the ECU sees the low coolant temp from the ECT sensor. The ECU responds by telling the IACV to bypass more air to the IM, resulting in a higher idle speed. The idea behind the high idle speed when cold is to shorten the time for the engine to reach full operating temp, which is best for performance and fuel economy.
So now you can see why a goofed up ECT sensor or circuit can cause a goofed up idle.
Hysterically Calm
I never narc'd on nobody!
Both. If you use the wrong combination of belt/cam gear/crank gear on certain mini me setups, or even if a stock engine has had the head shaved too much, you can end up a quarter or half tooth off, which (under the right circumstances) can give a fucked up idle.
Hysterically Calm
Good stuff, thanks.
sporkcrx
11-09-2002 06:59 PM
