95 civic cooling fan problems
I have a 95 civic with a b16 swap my cooling fan wont turn on. replaced the relay in it, the fuses are fine. the radiator and fan are new. Any ideas on what i should do?
Re: 95 civic cooling fan problems
Voltage test both fan fuses. I assume you know which fuses to test as you have already concluded they're good.
Test whether both sides of the relay get voltage.
Test whether voltage reaches the Yel/Grn wire terminal of the fan switch connector.
Post the results.
Post the results.
Okay the relay relay is reading 11.38-11.40. But the connector doesn't read anything. Not the fan sensor, but the side that it connects into.
2 of the 4 terminals in the relay socket of the hood fuse box should have battery voltage with the key in ON(II). Apparently only one does?
Which 2 fuses have you tested for voltage? Click the Test Fuses link in my signature.
Does the connector for fan switch get voltage on the wire I mentioned?
Okay when i tested the connector I didn't get a reading at all? The left side of the relay is the side that doesn't read. the right side does. The wires you mentioned are they in the bigger sized connector that's shown in the diagram? or are you talking about the connector that plugs into the fan?
antballs420
09-24-2005 10:12 AM
