D to b series swap
D to b series swap
So I'm planning on swapping a b16 into my 2000 civic. It has a d16y7 in it. I know I'll need a different ecu, engine harness, axles, but what else would I need? Would also be wonderful if you could specify where to get it from also.
Re: D to b series swap
if you go to hybrid section, it has all the information you need.
quick crash list.
engine
transmission
flywheel/clutch/pressure plate
3 new axels ( driver, passenger and half shaft )
exhaust manifold / header
b series shift linkage
driver side 2 bolt post ( from 99/00 civic si) ( you can keep the engine mounts )
rear transmission mount from 99/00 civic si
ecu to match engine
probably a conversion harness
rewire distributor
rewire iacv
add vtec wiring ( if going vtec b series , if going b18b or b20 , not needed )
radiator hoses to work with the skinnie stock rad, or upgrade to alu rad
added things you might need aswell
coolant
oil
oil filter
transmission fluid
ball joints ( if you wreck them during swap, or if they are old )
quick crash list.
engine
transmission
ecu to match engine
rewire distributor
rewire iacv
coolant
oil
oil filter
transmission fluid
zach2004t
07-19-2010 04:40 PM
aaronboy123
04-17-2009 07:16 PM
