Will a 96 LS rear sway bar fit 2000 4dr EK?
Ek Forever y0!
Re: Will a 96 LS rear sway bar fit 2000 4dr EK? (spectacle)
No, you'll need endlinks and D brackets.
And really you need a subframe brace because a swaybar can and will tear out your subframe.
stock integra (non-r) will not hurt the subframe at all
With the proper mounts and links, you would be good to go.
The em1 bar is 1mm smaller than the teg bar. It does, however, have the proper links, and if it comes with D brackets you would be all set.
Neither makes a huge difference in handling....some, yes...but nothing spectacular.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">stock integra (non-r) will not hurt the subframe at all
Neither makes a huge difference in handling....some, yes...but nothing spectacular.</TD></TR></TABLE>
THANKS!!!!!
THANKS!!!!!
vega5415
10
05-28-2013 08:16 PM
