smoke from radiator cap please help
93 honda del sol d16z6 vtec. after driving there is a lot of smoke or steam coming from the radiator cap. anyone know what's going on?
The cap must be bad. Because of the temperature and pressure, there will be "smoke" which is actually steam, but anywho. Make sure the cap is on alllll the way, and then try replacing it. Cheap fix.
Re: (Vt3c_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg »</TD></TR><TR><TD CLASS="quote">if it boils its the your head gasket. it happen to me.have you replace that yet?</TD></TR></TABLE>
yeh but he would overheat all the time from that. I would hope the headgasket is the last step. Its not like changing the gas cap.
Re: (SL!M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL!M »</TD></TR><TR><TD CLASS="quote">The cap must be bad. Because of the temperature and pressure, there will be "smoke" which is actually steam, but anywho. Make sure the cap is on alllll the way, and then try replacing it. Cheap fix.</TD></TR></TABLE>
x2.....$10
x2.....$10
check where your radiator cap goes onto. on mine it leaks because its chipped a little. and the cap doesn't lock tight. so i have a little antifreeze leaks. which creates the smoke i see. good thing i have a good radiator i just need to replace it.
dpkelly
12-08-2006 10:39 AM
