B16 obd2 oil pump on GSR
Alright H-T the question here is can I use a B16A2 OBD2 oil pump on a B18C1 obd1 block? If so I've looked but can't seem to find a list of compatible parts, anyone know if there are things that can be swapped over to the OBD1 gsr?
Re: B16 obd2 oil pump on GSR (EM1_00Si)
Yes you can use it.
The only difference between an OBD 1 and OBD 2 oil pump is the sensor on OBD2 oil pump
but if installing into OBD 1 car...you dont need to hook up the sensor. I think it's an oil pressure sensor
Re: B16 obd2 oil pump on GSR (Mr.R)
Well the oil pump is coming off my 00 B16A2 and goin onto a OBD1 gsr. The car will otherwise be staying OBD2 with an OBD1 conversion harness for tuning purposes. I need to keep it OBD2 otherwise for inspection.
On that note anyone know themselves or where I can find what parts on a b16a2 block are interchangable with a b18c1 block? Thanks for any help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.R »</TD></TR><TR><TD CLASS="quote">Yes you can use it.
but if installing into OBD 1 car...you dont need to hook up the sensor. I think it's an oil pressure sensor</TD></TR></TABLE>
Crankshaft Fluctuation Sensor, for monitoring the crankshaft waveform to determine engine misfire.
Re: B16 obd2 oil pump on GSR (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">
Crankshaft Fluctuation Sensor, for monitoring the crankshaft waveform to determine engine misfire.</TD></TR></TABLE>
there we go!
lol I was taking a while guess with the oil pressure sensor but that isn't located there regularly anyways
thanks for correcting me
there we go!
EM1_00Si
06-10-2007 09:01 AM
blu3g
08-09-2005 04:31 PM
