Clutch Rattle
Clutch Rattle
When I have the clutch engages on my 1993 Honda civic it makes this rattle/grind noise. Sometimes it's not there and it goes away when I press in the peddle. Any idea's in how to fix this or adjustments or anything of the sort.
Re: (tei344)
BUMP
I HAVE THE EXACT SAME PROBLEM ANYONE KNOW ANYTHING ELSE IT MIGHT BE I WAS TOLD IT WAS THE THROWOUT BEARING ALSO BUT IM THINKING SOMETHING IS JUST LOOSE ITS ANNOYING!!!!
Re: (97Ej6mike)
i just had a input shaft bearing pwn my z6 tranny after 30,000miles with that bad bearing it killed my 1 2 and reverse gears. i had a new motor and trans rdy tho. it finally went out when i was doing a 4th gear burnout on ice. o well
KHaoTiK
12
02-23-2010 02:29 PM
