Door Does Not Open
GO GIANTS!
Door Does Not Open
My gf has a 97 DX Coupe. The problem is is that the passenger door does not open.
In order to open the passenger door you have to open it from the outside by putting the key in, turn to the right, and while doing that lift up the handle and the door opens. You can not open the door from the inside. Any suggestions where I should start to try to fix this?
Very dangerous
Very dangerous
Re: Door Does Not Open (HondamanXxX)
Open the door and take off the interior door handle, then take off the interior trim panel. Check behind there and make sure all of your linkages are hooked up. My guess is that they aren't, or that they're bent or something. You might also want to pick up a different exterior door handle.
coloradod16
11-13-2008 01:33 AM
KidMo
01-15-2003 12:06 PM
