Boost or not?
Boost or not?
Well i have a D16Y8 with 166k miles.. i also have a junkyard turbo setup but im not sure itll hold since it has too many miles on it!!!
im also trying to work on a LSVTEC setup i have..
what do u guys recomend boosting 166k miles or save on LSVTEC???
TIA
TIA
Do a compression check and if the engine is in good shape and you take care of it I don't think it would be too bad. Just make sure its tuned correctly with your setup of choice and you don't boost too high. Good luck.
Re: (SL!M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM »</TD></TR><TR><TD CLASS="quote"> save on LSVTEC???
TIA</TD></TR></TABLE>
or do a b18 build
or do a b18 build
Re: (97Ej6mike)
Don't boost... Save that money and put it towards the LS-Vtech... Or just kinda look around for a good GSR swap around the same price... I've seen some GSR swaps with under 100k go for around the same price as LS/V-tecs but then again... i'm a GSR guy so I guess my opinion is biased
Re: (Agent_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent_EM1 »</TD></TR><TR><TD CLASS="quote">Don't boost... Save that money and put it towards the LS-Vtech... Or just kinda look around for a good GSR swap around the same price... I've seen some GSR swaps with under 100k go for around the same price as LS/V-tecs but then again... i'm a GSR guy so I guess my opinion is biased </TD></TR></TABLE>
x2 and more reliable and less hassle
Re: (MDM)
if this is gonna be ur daily driven car and ur not tryin to be the fastest u can den do lsvtec or gsr... but if u want speed i say sell the lsvtec and use it to build ur D series and den throw the turbo on it and get a good tune. but be prepared for a lot of downtime if u decide turbo.. but i gurantee u one thing. once u go turbo u wnt wanna go back lol i didnt
Re: Boost or not? (MDM)
166k miles is pretty high...if the body of your car is still good then jut get a new engine if your body of your car is bot good anymore might as well get a new car. in my opinion anyways
Re: Boost or not? (em1_racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_racer »</TD></TR><TR><TD CLASS="quote">166k miles is pretty high...if the body of your car is still good then jut get a new engine if your body of your car is bot good anymore might as well get a new car. in my opinion anyways</TD></TR></TABLE>
the cars good all it needs is pait so i might go GSR!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_racer »</TD></TR><TR><TD CLASS="quote">yea if the car is still good then screw the d engine...go gsr</TD></TR></TABLE>
will do.. u think i could get one for about 1k???
Re: Boost or not? (96teggylsse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggylsse »</TD></TR><TR><TD CLASS="quote">you dont have to drill any hole.... i have 96 ls vtec and i just got the golden eagle conversion kit!!! </TD></TR></TABLE>
how does that work??
where did u get it??
how much??
lol
how much??
lol
im going to go with stock bore b16b (ctr) pistons when i rebuild they make about 12.3-1 or something like that with the gsr head.... what head are you using??? i guess it depends if you are going to go turbo or not later..... keep us posted
yea thats the thing i heard its not recommended to use ctr's since i am going to be boosting in the feature and i dont wanna change pistons later on.. i might use a b16 head so i was also thinking b16 pistons and b16 tranny! so what do you all think..b16??
just buy a bare block and build it I may consider selling my setup, I have a bare b18c5 block with oil pump main caps and girdle, and brand new wiseco pistons and eagle rods for 81.5 mm bore and a polished ls crank
