Clunking from rear of car over bumps
(banned)
When I go over larger bumps or speedbumps, I can hear a clunking sound from the rear of the car, might be coming from the passenger side. I just changed both rear shocks (gotta love those snapping bolts) and I also double checked to see that my exhaust was secure and not hitting anything. What could be causing the clunking?
Re: Clunking from rear of car over bumps (Jizzmaster Zero)
have you checked the condition of your rear trailing arm bushings? also do you have a rear sway bar, endlinks make clunking sounds when they are going out.
(banned)
Re: (specialized108)
The LCA bushings are in great shape, I replaced 3 of the 6 when installing the shocks.
Spare tire and jack are securely mounted, not moving.
I have one 12 but the clunking is the same from before I had it
Car isn't lowered.
Shocks were assembled correctly.
No rear sway bar.
Trailing arm bushing are cracked here and there, but they still work fine.
Thanks for the ideas, keep em coming if you have more
Car isn't lowered.
No rear sway bar.
Re: (Jizzmaster Zero)
could be rear wheel bearing. grab the tire like a big steering wheel and shake it violently. if it has any play then you need to replace the rear hub assembly. About a $75 part.
(banned)
Re: (pimpinblackcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpinblackcivic »</TD></TR><TR><TD CLASS="quote">check the shock topmounts are torqued correctly and the spring properly seated</TD></TR></TABLE>
Check, they're fine too
(banned)
It's still happening. I've isolated it to the right side of the car. When my left wheels go over a speed bump, no noise. When my right wheels go over a speed bump (right rear mainly) I hear a clunking, sounds sort of like metal bouncing up and down a couple times quickly, or being dropped and bouncing once after the first impact.
my trunk latch is set a little high so i can push my trunk dorn about a quarter of an inch and when i hit a bump it makes a noise like that, it might also be you spoiler or rear bumper being loose. also if you get time please bump my thread "my car keeps cutting out! Why!!" i am trial and can't afford to bump and waste a post, if you have any input i am welcome to here it. thanks, hope you figure it out.
Re: (del sol b18c)
saw you just changed rear shocks, are the 2 top shock bolts tight, the ones that go into your fenderwell into your interior? I've had to re-torque those before after putting shocks in because they come loose.
(banned)
Re: (teal_dx)
Well funny thing is it was making the same noise with the old shocks, and they were torqued tight. I'll double check the nuts though, as well as the bumper and trunk latch.
Re: (teal_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx »</TD></TR><TR><TD CLASS="quote">could be rear wheel bearing. grab the tire like a big steering wheel and shake it violently. if it has any play then you need to replace the rear hub assembly. About a $75 part.</TD></TR></TABLE>
I ain't the starter of this thread, but you may have answered the problem of my gf's car
Check the compensator arm and make sure it is connected to the trailing arm and chassis, also inspect your XD XD XD XD trailing arm bushing... XD
Jizzmaster Zero.... XD what a splendid name... XD
Nerv2g
30
10-24-2003 01:09 PM
