fuel pump issues. please help
I have a built bottom end and boosted d16z6 in an eg hatch. walboro 255 FP. The car has been running fine for 2 years. Today I went to start it and the fuel pump is not priming. it was starting but would die, then it would start and idle but would die when I gave it gas.
I swapped the fuel pump and nothing, tried a known good main relay and nothing. My next thought is TPS but wanted some suggestions before I swap throttle bodies in a random store parking lot
Thanks in advance
Thanks in advance
Re: fuel pump issues. please help
Bad ECU... the fuel pump circuit may be damaged. Try another known good ECU... just to see if the car cranks and runs.
Chris del sol
04-16-2013 10:42 PM
93FlatBlackHatch
12-30-2006 03:22 PM
