My em1 build thread
Old 05-20-2018, 09:09 AM
Default My em1 build thread
Traded an 07 civic lx coupe in great condition for this, trade way down but had to save this car and didn’t need the 07 anymore
The day I picked her up
Nasty
So much eBay
nutz4vette is online now
Old 05-20-2018, 11:38 AM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: My em1 build thread
what are your plans?
eghatch9295 is offline
Old 05-20-2018, 12:01 PM
basically had the car about a year and a half now, swapped it with a usdm b18c5, did all suspension, was building it for auto x but spun a rod bearing last August, been rebuilding it turbo since then, block is done, Head is with my tuner atm, and already piecing my turbo setup together now, Iíll be posting everything step by step up to current soon
Old 05-20-2018, 01:08 PM
Oof. That poor civic.
Feriohhh is offline
Old 05-20-2018, 01:51 PM
So far
Block mods:
B18c5
Eagle rods
Wiesco 9.6:1 pistons
Acl main bearings
King rod bearings
Ati super street damper
New oem water pump
New oem oil pump
New oem gaskets and sensors
Arp head studs
Innovative 80a mounts
Hasport torque mounts
Head mods:
B18c5
Supertech valve guides
Ferrea 6000 intake valves
Ferrea comp plus exhaust valves
New oem valve seals
Sk2 pro series dual valve springs
Sk2 ti retainers
Sk2 Lmas
Sk2 pro 1+ Cams
Sk2 cam gears
Bdl fuel rail
Hondata intake mani gasket
Trans mods:
B18c5
Comp stage 4 6 puck unsprung kit
Russell as clutch line
Exedy master and slave cylinder kit
Suspension mods:
Progress cs2 coilovers
Function7 rear lcas
Sk2 lca hardware
Hardrace upper control arms front and rear
Hardrace trailing arm bushings
Hardrace rear toe kit
Asr rear brace 24mm sway bar kit
Spoon front and rear sway bars (legit)
Buddy club ball joints
Insane shaft 500hp axles
New Koyo wheel bearings all around
Misc mods:
Ktellar 3Ē mandrel exhaust
Vibrant turbo muffler and resonator
Mishimoto radiator, fan, and hoses
Chipped p28 on neptune
Buddyclub p1 wheels (white)
205/50/15 nitto bro gens
Optima yellow top battery
B&Mshort throw
Old 05-20-2018, 02:02 PM
Future mods:
Garrett Gtx3582r with rial v band housing
Sheepey a/c compatible t3 top mount manifold
sheepey 850hp intercooler
sheepey catch can(have)
Custom downpipe
Custom intercooler piping
turbosmart 45mm hypergate (have)
tial Q 50mm bov (have)
jbtuned full e85 kit
Walbro 450lph pump
injector dynamics 1300cc injectors
Aeromotive fpr(have)
omni 4 bar map (have)
Aem Air/fuel and boost gauge (have)
Defi water temp, oil press, and egr gauges
and of course a retune
Old 05-20-2018, 02:50 PM
Old 05-20-2018, 03:40 PM
Sanji
toyomatt84's Avatar
Relax with the repeat posts, bud. Your pictures were flagged as unapproved, so a staff member had to approve the posts. Its a setting we have no control over, sadly.
toyomatt84 is offline
Old 05-20-2018, 03:55 PM
Itís all good, sorry, thought it was a problem on my end
Old 05-20-2018, 04:05 PM
Wheels and suspension
Old 05-22-2018, 06:25 AM
moAr!!!
:D
SonicC is offline
Old 05-22-2018, 06:20 PM
Freedo_Civegra's Avatar
Thank goodness you rescued it! Do the bolt heads on those UCAís hit the fender well?
Freedo_Civegra is offline
Old 05-22-2018, 08:47 PM
Nope, all good
Old 05-23-2018, 10:51 AM
sub'd to this thread
nagami is offline
Old 05-24-2018, 03:20 AM
Just wanted to show some of the treatment I saved the car from, this car did have high mileage from what I understand but every single panel on the car was straight and matching number, and even the motor and trans vin matched, but the exhaust was rusted in half, break pads worn down to nothing, every single suspension bushing worn out, ball joints sway bar links and tie rod ends worn out, all 4 ball joints
completely shot, had eBay rear camber kit but was only held on the body side by one bolt on both sides and they were loose, and then there is the subs everywhere, I still have to get and weld in a rear panel, and he ruined the doors completely
Old 05-24-2018, 03:22 AM
I have fixed everything mentioned above accept where the speakers were, I have doors but they are black so wonít be put on the car until i respect the whole car, and same for the panel under the window
Old 05-24-2018, 06:30 AM
Dang! Forget I said rescued: you straight up brought redemption to that thing.
Old 06-07-2018, 11:24 AM
Old 06-08-2018, 04:56 AM
Turbo time!
Old 06-08-2018, 05:26 AM
CandyRedRC46's Avatar
Engine build specs please.
CandyRedRC46 is offline
Old 06-08-2018, 03:47 PM
Everything done to the car is listed above but in a nutshell, b18c5 with wiesco pistons at 9.6:1 compression and eagle rods stock sleeves, Head is getting redone at the moment with new Supertech valve guides, Ferrea 6000 intake and comp plus exhaust valves, fresh valve job and new oem seals, Skunk2 valve springs, ti retainers, lmas, pro cam gears, and swapping my pro1 cams for tuner1 cams, the turbo is pte 5858 and probably gonna do a speedfactory a/c comparable ramhorn
Old 06-11-2018, 06:14 AM
I was hoping for more specific details, anyways, why the down grade from pro1 to tuner1?
Old 06-18-2018, 12:41 AM
My list up top is as specific as it gets, literally everything done to the car, and I am going to tuners over pros Because I am going to be running a 5858 turbo and the pro ones require a 62 mm turbo are bigger which is way overkill and way too laggy for what Iím building seeing as how I only am shooting for 500 hp The original goal was to build everything to support way more horsepower when I got my forged block done but now Iím just going to have it at 500 probably for good even with forged block later
Old 06-18-2018, 12:42 AM
I meant sleeved block, my current one has forged internals but stock sleeves, night shift got me not thinking straight lol
Old 06-18-2018, 12:49 AM
I have however change the turbo set up that I have in mind I purchased a 5858 from here and now looking at a KLM or speedfactory AC compatible ramhorn manifold instead of a topmount and GT35r
Quick Reply: My em1 build thread
  • Ask a Question
Question Title:
Description:
