Code problems
Old May 2, 2018 | 08:30 AM
Corey Masson's Avatar
Default Code problems
Hey guys, new around here. I just bought a 98 civic coupe swapped with a d16z6 vtech motor. The whole car needs a bit of help here and there for the most part she drives awesome and is really clean.
However, I just need no codes to pass inspection. I ran her to autozone for the free reading, and the first time it didn’t work. No fuse in the interior light spot, fishy. My CEL is not on, but it’s also a CRV cluster. I think he intentionally messed with the CEL. I put a fuse where it belongs, bam interior lights and obd reads. Here’s what I got for codes, the car starts and drives absolutely fine, so I’m not sure where to start whatsoever. What would be your suggestion? All the low input and circuit **** makes me think wire harness needs help? Any help is much appreciated.
Old May 2, 2018 | 06:28 PM
Turbo1983's Avatar
Default Re: Code problems
If I'm not mistaken but the d16z6 doesnt have a few of those parts that are listed. That's a obd1 in a obd2 shell.
Old May 2, 2018 | 06:30 PM
Turbo1983's Avatar
also on a d16z6 it only has 1 O2 sensor. Also if I'm not mistaken it doesn't have a crank sensor.
Old May 2, 2018 | 08:53 PM
I see, some of the problems like the speed sensor I know what the cause is. What would I have to do to get rid of the codes for the items listed that a d16z6 doesn’t have? New obd?
Old May 2, 2018 | 08:59 PM
Because the engine is from let’s say a 95, Id want to change OBD2 to match OBD1?
sorry for being such a noob I appreciate all help!!
Also: the ECU is the stock 98 one. So perhaps I’ll need a 95s ECU? Then those codes for the parts that don’t exist on the car should go away.
Old May 3, 2018 | 01:03 AM
eghatch9295's Avatar
Stancetard Hate Monger
ckf can be bypassed, google that one. you cannot add knock to the z6, and there is no reliable bypass i am aware of. running an obd1 ecu would make the obd port in your car inoperable, depending on where you live, that is an automatic fail for emissions.
Old May 3, 2018 | 03:51 AM
mk378's Avatar
It is take quite a bit to make that car pass smog. Is there a law there that makes that the responsibility of the seller?
Codes for the speed sensor and both O2 sensor heaters at the same time is often the fuse 15 problem.
Old May 3, 2018 | 07:53 AM
They hacked the wire to the speed sensor, which is why it’s not working I believe. I will take a look at the bypass.
So if the OBD becomes inoperable with a new ECU to match engine, could you change both ECU and OBD? I seen some kind of adapters online, I’m unsure if they’d be any use to me.
Amazon Amazon
My my concern lies with the other codes I won’t be able to get rid of, if I can’t get rid of them she won’t get inspected D:
Also NH law is 20 years emissions don’t matter. I just made it ahaha, so I need a way to fix all these other codes. With an adapter and new ECU for a 95 will I be all set? Then I will obviously have to tackle speed sensor and electrical load.
Old May 3, 2018 | 09:29 AM
if the inspection process doesn't require plugging in, then yes a jumper harness and p28 will work
Old May 3, 2018 | 09:36 PM
Then I’ll need to change the OBD as well? All I really need is to get rid of all the codes and I’m set for inspection. It will be plugged in.
Old May 4, 2018 | 04:35 AM
mk378's Avatar
Since it's a 1998 car, they're going to plug in an OBDII scanner, thus it has to be running an OBDII system. You cannot install an OBD1 ECU because an OBDII scanner cannot link to it.
And that means you need the CKF and knock to be working.
Old May 4, 2018 | 07:13 AM
Which is technically impossible because a d16z6 has never had a knock sensor?
ahh apparantley there IS a way to bypass both knock sensor and CKF. I’ll take a look, you guys have been super helpful.
Thanks guys, I’ll return to this thread if I need help with the other codes.
Old May 4, 2018 | 07:48 AM
the knock bypass is super ghetto and unreliable.
Old May 4, 2018 | 07:51 AM
I really have no other choice, I need these codes gone or I can guarantee she’ll never see an inspection sticker. 😭
Old May 4, 2018 | 07:59 AM
I mean, if I changed to OBD1 ECU with jumper harness couldn’t I just tell the mechanic it’s swapped which is why youll have to use OBD1 scanner?..
Old May 4, 2018 | 07:04 PM
there is no obd-1 scanner. i would call, play dumb and ask what the procedure is if your obd port is non functional. maybe, theyll let you tailpipe test it.... BUT remember that they are harder to pass than the code reader test, for obvious reasons.
Old May 5, 2018 | 02:20 AM
So there’s literally 0 ways I can get rid of all these codes, because my engines swapped?
Old May 5, 2018 | 08:08 AM
nothing that will keep that obd scan port working. you need to ask if tailpipe testing is an option, if it is, then you can use an obd-1 ecu and jumper harness. if not, you'll have to try that ridiculous piezo transducer bypass thing for knock.
mikej94civex
Dec 15, 2009 01:18 PM
crazi92hb
Nov 22, 2006 05:20 PM
tyoung
16
Sep 6, 2006 11:53 AM
JDM-EJ1
Jul 7, 2004 05:33 PM
Goy091
Jun 23, 2002 01:33 PM
