Do i need rear camber adjuster, alignment ok?
Here is my Vehicle Alignment Report after a 4 wheel alignment on my 95 honda civic daily driver street car.
Are the specs right? Did they do a good job? Mechanic said i need adjustable rear camber but i heard these cars don't in most cases. Do i need it? I have adjustable coilovers but car isn't extremely lowered but is lowered maybe an inch with 16" tires.
Fish Twig
Re: Do i need rear camber adjuster, alignment ok?
You should try to learn to read that sheet, so you'll understand whats going on. If the alignment shop says you need it then you need it.
Hey I didn't remove the alignment sheet but some people have said they can't see my pics but idk why.
the mechanic acts like I'll be ok without the adjustable rear cambers but I guess I'll get some.
i can read the data sheet ok it makes it easy because the red numbers are out of spec and i know all the terms under the primary angles, jw if anything looked wrong to y'all besides that.
so i got Hardrace brand rear adjustable camber kit
FreshJr
02-14-2014 06:22 PM
michael-crxsi
14
11-30-2009 09:03 PM
killercrx91
09-23-2008 08:16 PM
