valve job need help choosing new valves
i have a 92 civic 5 speed 1.5 D series i belive i have to do a valve job on it and i figured if im have to replace them then this was the time to start building my race motor so im wonder what valves do you guys think i should put into it for best performance. thanks in advance
Re: valve job need help choosing new valves
Most people are going to tell you to junk the entire engine/trans and b swap it. I am just going to tell you to junk the head and do a mini me.
A B head will not fit on a D block. Though it is possible to race anything, nobody seriously considers going racing with a non-VTEC engine.
Instead of spending lots of cash on new "upgraded" valves and everything that goes with it (new seats, valve guides, seals and oversized valves, and full port and polish).
I would just have a standard valve train rebuild done on it with stock valves, maybe upgrade your springs, retainers and keepers.
And then put a D16A2 camshaft (I think from the 1988 in particular) into your D15B7 head.
This has proven to be a very solid performance boost to the non vtec D15B7. If you do a google search for D15Beast7 you should come across a very helpful bit of information.
You will save a fair amount of money and maximize the performance of the nearly already maxed out motor in your car.
also i pulled the codes one day and it was throwing vtec codes could that be because the ecu is for a vtec?
The piston and cylinder are likely trashed from that valve head bouncing around. So it's looking more like replace the whole engine.
Yes of course you get VTEC codes when connected to a non-VTEC engine. You can move a jumper inside the P28 ECU to make it run as a P06 and not throw VTEC codes if you really want a non-VTEC engine.
Also looking at the picture of the head and valves, it looks like it already has had a real mix mash of valves stuck in it.
Couple that with vtec ecu on a non vtec motor.... This really looks like a full on hack job of the worst kind.
I too would border on the base motor is not worth working with and look at a different motor to put into the car.
The very first picture shows all the valves on the head, some look flat, some look like the OEM curved divot and others look like a machined divot.
To boot, this mix mash is on both intake and exhaust from the appearance in the picture.
Red circles, some are flat, some are divot.
Blue circles, some appear to be flat (could be picture) and some are smooth curve divot and the one is machine cone like divot.
Black circles, the left side looks like a bigger seat than the right two.
This head has had a number done on it in my opinion.
As for piston damage, see the first post in this thread to see a picture of what a valve bouncing around in the cylinder does to a piston:
https://honda-tech.com/forums/honda-...ngine-3311746/
Attachment 510071
Attachment 510071
I would if it were mine. I believe many others here would too. Easier to build up another platform than to correct that one and build it up.
Also as an FYI for you, the D15B7 isn't a well supported motor as there isn't much potential in it for more power over stock. Support tends to be on engines (any brand) that end up having a decent amount of power that can be unlocked.
If you do some research you will likely find that even throwing a lot of money at the D15B7, the gains aren't that great.
Simply put, the D15B7 is a great little cheaply modded motor to learn on and have some fun, but that's about it really. And by cheap, I mean with other honda parts making a minime or the beast7. But spending significant dollars on aftermarket internals just doesn't give you enough bang for the buck.
LOL no you do not.
KYS bro
KYS bro
