sway bars on my 92 vx
hey guys i have a 92 vx no sway bars im gonna go with the itr 23 mm and asr subframe brace on the rear ont he front i wanna do the 25mm one but i was told it cause understeer and it pulls theires in and wrecks ur tires when u corner andyone help?
Re: sway bars on my 92 vx
What are you gong to do with the car? Is it a daily driver are you going to race the car there are a lot of things that go into picking a sway bar. If you are dd with little to no track time I would go with the oem front sway bar from a 94-01teg or 92-95 civic si/ex. You should be able to pick one up cheep at a salvage yard. I would go with the rear sway bar off the 94-01 teg you will have better luck finding one. I think the only civic that of that erea that came stock with rear sway was the 4dr lx and 4dr ex. since your car is the vx you will need the lower control arms front and rear of a doner car that came with swaybars. Other wise you are better off just getting an after market system that can be mounted to your lower control arms. I think all said and done I picked up a comp rear sway bar with lower control arms all the bracket and mounting hardware and the integra front sway bar for under $50 at a local pick and pull. If you go to big on these things it can really mess up the handling of the car. I am running stock sway front and rear and with proper tire presure at the track the tail of the car is just loose enough to get the car to pivot really nice around the cones.
Edit one last thing a larger rear swaybar will cause the car to oversteer not understeer. Oversteer will cause the rear of the car to be loose and want to slide past the front in simply terms. To much oversteer in the hands of an unskilled drive means when you loose control of the car you leave the road spining and backwards. Where with understeer the car will push and go straight off the road.
thanks guys on my crx si i had stock front and rear slammed and handled awsome i think im gonna get stock si hb for ront and then integra for rear or stock for rear see what i can find
i had a 92 civic,i was going to post,if there are sway bar in the rear,because i don't see it,so it true there are no sway bar,right
correct the si did not come with a rear swaybar from the dealer. It is avail for it but you are going to pay an arm and a leg for it. It is just better to find one at a salvage yard.
Cosworth
02-21-2003 10:31 AM
