How can i improve my steering??
Hi,i´m from Spain
I have and EK,and i hate it steering because i think that it´s so soft. I would like that my steering becames harder
What can i do?¿
thanks
What can i do?¿
thanks
Re: How can i improve my steering??
without powersteering you have no help and its only you steering the car
so if you want your "harder steering"
take off the powersteering
if you have some mucles
then it wont be that hard
my homie is scrony, really scrony and have an Si with B20 with no powersteering and had no problems driving it.
youll get used to it after a while i guess
Non.
No hay otra solución amigo.
Ma, cuando el civic se está moviendo él será mucho más fácil de dirigir que cuando él y se parquea.
Translation:
No.
There is no other solution friend.
But, when the civic is moving it will be much easier to turn the wheel compared to when it's parked.
Translation:
No.
i know the answer for you my friend.
replace your 2 front tires with BALD tires.
that **** makes ur car hard to steer no matter what. especially with no PS.
get some old *** tires on them front 2 shindigs
what about a steering quickener? i read about it in another thread... it goes inline with the steering column and takes out a whole turn lock 2 lock.
is removing power steering as simple as taking it all off? or do you need to change/modify anything? id like to shed a few lbs but need to know if i need anything...
to jaujau:
unfortunately there is a language barrier, you can write english very well BUT it is still hard for us to understand what you mean by "harder steering."
if you could exactly explain what the car does that you dont like, it would help us find your solution.
is the steering too easy for you?
or does the car move too much when turning?
to jaujau:
thats what i think he means, but i just want to be sure.
if thats the case, ive noticed this is how most japanese setup their steering. quite a bit of assist. europeans tend to not assist as much. and its a tradeoff. less assist gives more feedback, more effort. more assist gives less feedback and less effort.
i see a few options here:
1) leave things alone and just deal with it.
2) take off the power steering belt.
3) take off the power steering belt and remove the pump, with the lines on the rack running in a loop
4) non power steering rack.
those are the options i see.
