right headlight only works when brights are on
one works fine but the other only works when i have the brights on, does any one else think this is the relay. or something else
thanks!
thanks!
Re: right headlight only works when brights are on
Could just be the bubls low filament no ? Did you check the wires to make sure one isnt loose and shorting out ?
when you say the bulb is brand new, do you mean you've replaced it since this problem started? if not change it again.
try switching the bulbs from the other side if it does the same thing check the fuses. did you loosen the ground on that side for any reason?
Yeah, brand new bulb from the parts store. It's been tested and it functions properly.
There's a fuse for low beam AND high beam? Where's the fuse? Under the dash or the hood?
You do know there are fuses under the hood as well along with various relays too, right? Anyway, it turned out to be a 10 amp fuse in the under DASH fuse block. I never knew there was a fuse for the high AND low beams. Learn something new every day lol.
Bambooseven
03-03-2009 08:40 PM
