00 civic ex o2 wiring need help asap !!!!
Re: 00 civic ex o2 wiring need help asap !!!!
also i need to know if some has a 2000 civic ex , if they could take a pic and post it of there o2 wire in the rear thanks
So this is for your secondary O2 sensor? Because no one can see the images you posted in that other link without registering for the site (I doubt anyone will do that).
Here are the wires listed from the service manual:
If I misinterpreted what you are saying (or for future searches) and it's the primary O2 sensor, here's that:
Regardless of which one you need info for, that should help you match up the wires. Match the White wire from the O2 sensor with the Wht or Wht/Red wire in the #1 slot, the Green wire with the Grn/Blk in the #2 slot, etc.
actually this helps kinda but , however i need to know what the wire code it for the ones coming from the o2 sensor to the car and where they go thanks as far as color to color , and yes its the secondary o2 ( but i guess its primary now because my car has only 1 o2 sensor)
well , ......it didnt , and now i have worse problems , all my dash lights came on today and now my car wont start , so i took off the msd ignition setup and order a new stock distributor and im hoping this will fix my problem ( i have no spark, i checked all the fuzes and 2 different msd boxes, 2caps , 2 rotors and 2 external coils, and still nothing) SO ill update once this is completed so thanks for all your help i really appreciate it .
Matt
Matt
