help with surging at idle 96 civic ex
i bought a 96 ex 5 spd with a bad motor.i swapped it with the motor from a 99 ex auto.all sensors and harness stayed on the 99 motor and i plugged into the 96 ecu.car surged real bad at idle.i figured out that the auto had a different manifold and iacv so i went and got the ecu that went with that engine and plugged it up.now i still have the surging but the engine ran fine in the old car that was wrecked.car runs good but idle bounces about twice a second from maybe 1200-1600rpm.did i screw up the iacv by plugging it into the old ecu maybe sending power or something into the wrong spot?does anyone know how to test the plug at theiacv with a meter to make sure it is right or test the valve itself.also will the car throw a cel using an auto ecu with all of the tranny harnesses unplugged?
-thanks in advance
-thanks in advance
Re: help with surging at idle 96 civic ex
yeah you will get a cel for an auto ecu in a manual car, look up the pinout for you ecu and make sure you have continuity between the iacv plug here's a link to the some pinouts http://hondaswap.com/reference-mater...pinouts-28667/ have you checked to see what cels you have, obviously you have atleast one for the auto ecu but just disregard that and tell us the other ones
turbo'ek562
19
03-30-2013 04:53 PM
