so much smoke
so much smoke
I did a mini me swap to my 96 civic hatch n I put a new header on n it only has 1 o2 sensor spot so I hook it up n now my car blows smoke everywhere I'm thinkin mayb its runnin to rich or lean.. Could it b smoking from the downstream 02 sensor not hooked up plez help I got pulled over 2 times already.. It smokes 4 like 5 min n then dosnt smoke 4 a while n wen I come 2 a stop 4 a while n go it smokes
Re: so much smoke
I did a mini me swap to my 96 civic hatch n I put a new header without a car n it only had 1 o2 sensor spot so I hook it up n now my car blows smoke everywhere I'm thinkin mayb its runnin to rich or lean.. Could it b smoking from the downstream 02 sensor not hooked up plez help I got pulled over 2 times already.. It smokes 4 like 5 min n then dosnt smoke 4 a while n wen I come 2 a stop 4 a while n go it smokes
how do you put a car in a header hahahaha
Location: Your house, your mom's house, your dog's house... basically anywhere you've been! haha
Re: so much smoke
Did you do the minime swap AND header at the same time? Different times?
Did it smoke before you put on the header?
Re: so much smoke
You already know what the problem is . . . as you stated yourself. and i quote
"Could it b smoking from the downstream 02 sensor not hooked up"
You know what the problem is, now get an o2 bung and be done with it already.
Re: so much smoke
Well I had the mini me swap once wit the old header n it didn't smoke n then I blew a bering n put another y7 block in wit the header n now it smokes.. No there's no oil I changed the spark plugs.. I put hotter ones thinkin mayb it wasn't gettin a good enuf spark n it still smokes.
Re: so much smoke
The rings shuld b good it smells like gas its white smoke n I checked my pistons no oils or nun they nto soaked so its not anit freeze I don't no mayb my spark plugs aren't that good nemore
Re: so much smoke
Ok so I changed thbe spark plugs n it dosnt do it as much as often.. I had put new plugs in wen I did the swap but mayb since I didn't have vtec wired 4 a while it made the spark plugs like **** but thx 4 the help
george34
10-31-2005 01:02 PM
oldskooljdm
11-26-2003 11:18 PM
