Speedometer & Odometer don't work
my speedometer and odometer aren't working but cruise control works. any helps will be great. thanks
Re: Speedometer & Odometer don't work
If CEL is on, check the CEL FIRST!!
If the CEL pertains to the speedo sensor, ding ding ding, it's probably just the sensor located ontop of the transmission.
If CEL is NOT on....
Problem: The speedo doesn't work but the odometer works.
Solution: Replace the cluster or just replace the speedo gauge
Problem: The speedo doesn't work AND the odometer doesn't work.
Solution 1*: Bad Sensor - Replace the speedo sensor in the transmission.
*CEL should be on
Solution 2: Bad Gauge - Replace cluster or just replace the speedo gauge
IF Neither solution above fixed it.
Solution 3: Check all wiring from the sensor to the gauge. Because the signal is disrupted somewhere.
*CEL should be on
