b18a1 wiring issues
b18a1 wiring issues
ok this is whats going on
i have a 98 civic dx and i'm swappin in a 93 b18a1, on all the post telling you how to do the wiring they say to use a ex 5sp harness but i was figured they only said that because they were swapping in vtec too, so i decided to save money use my stock dx harness
but im having a bunch of problems wiring this and cant afford a harness from rywire or anything so if anyone has some sort of diagram or any tips please let me know
Re: b18a1 wiring issues
Ahhhh...see here inlies the problem my friend...unless your state allows you to run on OBD1 setup you are going to have plenty of issues with this swap. Your '93 engine is of course OBD1, but your car is OBD2. In order to make this run correctly (if it is even legal where you live) is to buy a jumper harness and use an OBD1 P75 or '92 - '93 integra ls ecu which is also OBD1 (PR4 I think). If not your ecu will be looking for things that your ls engine doesn't even have like a CFS, and a few other OBD2 only sensors. Tell us a little more about your ecu setup.
on-the-line
20
01-19-2007 02:30 PM
