How difficult is it to replace rack-n-pinion on an EJ1?
My rack and pinoin on my EJ1 has a leak in the passenger side power steering boot and so I have to replace it. My friend said his dad could do it for me at his shop, but I`m moving on friday and I am running out of time for him to do it, so I`ll be stuck doing it myself and not paying pepboys $700 to fix it... Is there anything special that I need to do the job? Special tools, fluids, etc?
Re: How difficult is it to replace rack-n-pinion on an EJ1?
I would say that I have above aaverage mecanic skills. On a scale 1-10, I would say that I would be a 6. And I can pretty much get any tools that I need, whether I buy `em or borrow them. Since I`ll be back at my house tomorrow, I will be able to do the work and not have to worry about people saying I can`t work on my car.
I read the manual a few times, just like u said, the steering joint and the tie rods I know are going to be a pain. I`m not a big guy, so maybe the job will be a little easier lol. But, are there any specific tools that I need to do the job? Or just a rachet and patience.
Manual or auto? For a manual, I recommend that you look in the FAQs sticky for the DIY on removal of the "bitch" pin without using a hammer. You'll also need to separate the tie rod ball joint, which is best done with a proper tool.
Oh look, I can change this
^ For the record, I tried that no-hammer-bitch-pin DIY, and it was a miserable failure. Not meant for 19-y.o. vehicles driven on salted roads. In the end, a punch fit in perfectly, but you need to get the vehicle high enough to get enough throw with your hammer. Wear gloves. Also, don't lose track of the pin when you pop it out!
I'd still soak the pin in PB Blaster and give the C-clamp method a try first, though I do understand that rust and corrosion might complicate this approach.
Seagull Management
Hit your hand Eric? Pro tip: Hold the punch with a pair of vice grips, it's greatly reduced the amount of bruises I get on my hands. Only other thing I'll mention is the pin is really only supposed to be used once, even with our insane Canadian prices I think they're only $2 each.
Christ, did I ever. Was wearing gloves though, and thankful for that. I did lose the pin in the engine compartment for about 20mins til I tracked its trajectory.
Good tip.
Yeah there's a ton of stuff in the svc manual that says "replace" if you remove it. I don't listen to that a lot. Like - as IF that pin is coming out on its own. In what universe? One made entirely of PB Blaster? PLUS it has that clip over it anyway, just in case in that 1 in 100 billion chance.
Seagull Management
Seagull Management
At the pump and reservoir, actually if there's enough room to finangle them down through leave both attached and you wont have to open the P/S system at all (I did this once, but I had the engine and transmission out, so I'm not sure if the pump fits down by the engine) Once everything the P/S lines are unbolted from the frame rail and you have the bottom knuckle/u-joint unbolted at the bottom of the steering column, tie rod ends separated and that through bolt removed drop the subframe. I never did a '96 - '00 Civic specifically, but I've done a couple of '92 - '95s which are quite similar. It sure beats the hell out of trying to undo P/S lines in areas where you can barely turn a wrench.
Technical Hero
http://repo.jackmoves.com/v/erik/album106/album119/
here's a thread I used to convert my EK to powersteering, it shows some good pics
I leave the rack bolted to the subframe, and I leave the rear mount as well, just take out the through bolt that attaches it to the rear T-bracket.
What all is involved with dropping the subframe? It seems more involved than just removing these rear beam bolts:
Once removed, would the entire subframe structure shown in the picture below along with the rear mount and rack drop out? If so, is there enough room with the front end raised on stands to do this job? How heavy is this structure and is a transmission jack needed to lower and raise it?
Seagull Management
Tell me if I have this right. I would (1) follow service manual steps 1-12 for rack removal (see diagram in post 19 above), (2) remove the rear mount through bolt (bolt 3 below) and disconnect the feed and return lines at the pump and reservoir, and then (3) drop the subframe, right?
Thanks again. I'm unclear on all the bolts that must be removed to drop the subframe. I assume that the 4 driver's and corresponding 4 passenger's side rear beam bolts must be removed (see subframe diagram). But is there more to remove before the subframe will drop down?
And I do have the Harbor Freight Tools transmission jack below, so that might come in handy if I attempt this method. I used it to drop the transmission when I replaced my clutch. Would it work or would a regular small jack be better?
Seagull Management
cmshbsi3
13
03-21-2010 02:16 PM
