Burning oil...what to fix?
So my 95 civic dx coupe has started to burn oil, When i go up a hill and im really pushing on it people behind me can see that its burning. did a compression check and im getting pretty much 140 in each cylinder, what do i have to replace?
Re: Burning oil...what to fix?
Its actually kinda common in eg civics to smoke a little. If it's only occurring when your pushing the engine hard, then your prolly having some light ring blow by.
When you re ring the engine, it is much more involved then say just doing the head gasket? I guess I am asking if you do the head gasket, a lot more steps to re ring the engine?
How many miles on the engine? It's possible that your rings are acceptable and that the blown head gasket is the entire problem.
Seagull Management
Yes there's a lot more to it. Engine has to come out of the car, and be completely disassembled. Ideally it should be hot tanked. Then it needs to be honed. and you need you need to put in new rings and bearings, and at the point it's cheaper and easier to just swap in a low mileage JDM engine.
yea...swap is cheaper, and easier really.
headgasket is pretty easy, but rings....easier just to swap it.
2nd note...what kind of oil you using? Ive noticed (synthetic only) that if I use anything but Mobil 1....I burn a bit...I mean...a little little bit using just upon startup, and maybe a 1/2 quart between 8k miles oil changes...
with Mobil 1...nada...nothing
So if you use synthetic....switch it to mobil 1 and see if it changes it.
som3on3_10
05-20-2006 05:49 PM
ILLA_00LS
07-22-2003 12:06 PM
TORQUE MONSTER
04-23-2003 08:28 PM
