99 si sputtering problem
I know there is probably another thread addressing this issue but i can't find it so here goes, i have a 99 civic si and every time i shut the car off and then start it back up without letting it sit for at least a half hour it sputters really bad, almost to the point of shutting off, but then after a few minutes of driving it goes back to normal. If the car sits for a while before you restart it, it does not have this problem. I'm sure that it is a sensor or something but i have tried everything, new map sensor, new main relay, new fuel filter, fuel injector cleaner, im out of ideas and need some help, any insight would be greatly appreciated thanks!!!
Re: 99 si sputtering problem
I've been having stuttering issues, mostly at low idle, but also at low RPMs coming off of a stop, cleaned the IACV, fixed both problems.
Okay finally got to claning the IACV no luck, gunna try replacing the tps to see if that fixes the problem, and i do have a cel but ive had it since ive had the car and this problem is new!
sikvic00
44
04-07-2011 05:24 PM
dohcem1
19
06-01-2009 09:35 PM
FearTheH
23
02-26-2008 08:05 PM
