Quick shock tower plug Wire Question
In the middle of extending wires and I ran into a problem with my drivers side shock tower plug.. It has 14 wires that come from the connector, problem is there's TWO(2) wires that are BLACK/YELLOW.. I'm not sure how to tell the difference in order to solder them to the other side..
Any help? Or at least where they go to?
They are numbers 1 and 5 with the clip facing upwards
Re: Quick Wire Question
Do you know what the two black/yellow wires go to? From there you might be able to temporarily hook them up and see if they are workin and if not switch the two and then see if they are working.. Hope this helps
Re: Quick shock tower plug Wire Question
I just took the dash out of my sedan and looked to see where the wires run from there, idk why I didn't think of it in the first place
one slow coupe
12-26-2004 12:24 PM
