cheap B series swap?
Re: cheap B series swap?
It used to be that the B20 was cheap. You had the B20B (lower compression) and the B20Z (higher compression). The B18a/b was either in between the two in price, or it was 3rd cheapest. Then the B16A. Next, B18C1. B18C5. And most expensive, B16B
The order has changed recently it seems. The B20 has gotten more popular and the prices have gone up. The B20, B18 "LS", B16 and B18C1 are your main choices. Depending on your budget and availability of each, will determine which is the best choice in your situation.
The least expensive B would be a stock B18a paired with either a hydro or cable LS trans, depending on the chassis in which the drivetrain will be installed.
I ended up getting a good deal on a b18 swap out of a riced out integra. the kid wanted 400 bucks for the whole car. I brought it home, tore it out, and scrapped the car. There are typically a decent amount of deals like that on craigslist. granted ill be way over $400 dolars when this swap is complete...
having a donor car like that^^ would save me alot of money and time looking for other various parts ill need right?? because besides the motor what else woult one need??
1 Post
el ez... lol what a pathetic useless swap.... b16 what a waste. only cheap swap isnt worth it. "go big or go home" "do it right the first time"
Unfortunately i didnt! i had no way of getting rid of the shell without all the suspension components, and i didnt have enough time to do the brake swap before i had to scrap it.
What makes them different? keep in mind ALL USDM B series/D series are 32mm. Only difference is the JDM ITR with 36mm.
The axles are different and will need to be swapped to B series, but the knuckles are just fine.
91CrxMann
34
05-15-2015 05:15 AM
live_again_integra
02-10-2005 08:28 AM
