B18b with YS1 Trans Axle Question
I'm dropping a B18b with a YS1 cable trans into a 94 DX and I'm having trouble finding a straight answer on what axles to use. Can I use 94+ Integra axles or do I need 90-93?
Seagull Management
Re: B18b with YS1 Trans Axle Question
to add to what Mcvtec said make sure that whichever intermediate shaft you use you use the axle seal that goes with it, failure to do so will result in a massive oil leak.
As far as mounts go exactly what mounts would be needed? Because every mount kit I look at says for use with hydraulic transmission only.
Seagull Management
hasport makes a set of mounts, as well as a couple of other companies, you'd really be a lot better off buying a hydraulic tranny though, or even a case, YS1 guts will swap over.
JJ-Built
01-02-2002 08:27 AM
