Oil in plugs?
Oil in plugs?
There's oil in the spark plug, what does that mean? Headgasket leaking? Spark plug loose? I'm changing spark plugs and wires this weekend just wondering if theres anything i should be looking out for since theres oil leaking into the wire plug.
Re: Oil in plugs?
yea...make sure you also change the valve cover gasket (with a dab of RTV) so you arent leaking from there also.
O rings on the spark plug tube is a 10 min job....super easy...
Re: Oil in plugs?
though if there's no oil seepage at the top of the spark plug, you may have to replace the LOWER tube seals as well
91302-PJ7-003 [x1]
91301-PJ7-000 [x3]
but you've gotta remove the valvetrain, and do a valve adjustment for that.
Re: Oil in plugs?
yea man i had the same issue about a week ago. autozone has just what you need and you will be all good. the plugs should be at 20lbs. it seems more then i thought but thats what my book says.
