jdm d15b Vs. d16z6 difference?
Hey im just curious the differences if the jdm D15b and d16z6 cause i wanna start a turbo build and wanna know which one is best for that application
1 Post
Re: jdm d15b Vs. d16z6 difference?
z6 more "aftermarket" support such as rods and such. everything is pretty much identical except rod length and crank, deck height. the 1.5 has a better Rod 2 stroke ratio meaning you can rev higher and less wear on your cylinder sleeves. but the 1.6 has a bigger crank meaning you will have bigger displacement and more torque. and also easier to find rods and such.
alright thanks alot. when i start the build i would like to build the bottom end and such. i havent seen a lot of atermarket parts for the jdm d15b. much more for d16. ima take a look at the zc motor.
Slammd Sol
37
01-11-2005 03:52 PM
