del sol knuckle help
i have a 94 del sol vtec i got it and the drivers side tire was cambered in like it was lowered it all stock hight so i got camber kit and it helped alot but still off. i think it a bend knuckle. i got a knuckle off a 95 teggy will this be the same??? or wat car would have the same knuckle cause finding a del sol vtec with the b16 in a junk yard is slim to none....
Re: del sol knuckle help
I can't imagine a knuckle bending. Check the upper control arms, bushings, etc if anything is bent.
And no, not all knuckles are the same. There's the "DX" knuckle with an 8.8" rotor, the "EX" knuckle with 10.3" rotor (same as an Integra RS) and the ABS knuckle (EX with ABS and Integra LS, GSR" with the 10.3" rotor, but it has bolt holes for ABS line and sensor probably. If you don't have ABS, easy, just use any Integra knuckle and swap your caliper bracket over to use your pads.
I'm not 100% sure if it's the Integra knuckle in general, or the Integra ABS knuckle, but I know one has a different caliper bracket that uses bigger pads
And all Civic, Del Sol and Integra parts can be swapped around, like knuckles can be done in pairs, etc.
Knuckles bend. It's not noithing new. BUT, you would have to be a pretty good wreck to bend it.
Also, if you bent the knuckle I am almost positive you would have other bent parts.
Has the car ever been wrecked?
i ended up replaceing just the drivers side with a knuckle from a 95 integra with abs. took the abs off and did some measurements and everything looks to be the same. going to get coil overs i think skunk 2 kit. the coil overs and shocks. and rear camber kit. than take it to get alighned... and guy below yes i found out that the bushings on the upper control arm were bad i ordered new bushings as well...
mugenNR10
07-14-2011 12:10 PM
gmacarize
12
10-27-2008 06:26 PM
5thGenFanatic
10
09-13-2004 07:58 AM
