97 civic depo side markers help
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
i found those on ebay for pretty cheap and wanted to no if they are good
i want clear side markers and they are cheap.
also i was just wondering if those sidemarkers provided in the link comes with everything needed to make them work.
Re: 97 civic depo side markers help
Link don't work. DEPO is an OEM replica. Install like OEM and work likes OEM. It should include side marker, bulb, plug and pig tail harness. Search for the how to. There's even a PDF templete for easy DIY.
the link does work
can you not see it?
i just dont no if that will work tho because there is a little harness and im not sure what i would do with it.
heres the link once again:
http://cgi.ebay.com/ebaymotors/ws/eB...d=250902020435
can you not see it?
i dont know what else youre looking for?? comes with the lense the two fires 1 for each side and a bulb nothing complicated aobut it
The Grumpiest
Those are garbage. I doubt that those are Depo. They will cloud up over time and let condensation in. Also you have to do some wiring-not so easy for some. If you want it plug-n-play then you can buy a wiring harness that will cost you twice as much as the side markers themselves.
If you continue to put cheap, bottom-of-the-barrel parts on your car it will show.
jdmitr98
09-09-2004 08:18 AM
tyronebiggums
08-13-2003 12:36 AM
