lowering problems
lowering problems
ok so i have a 93 del sol s model. the guy before me had cut the springs and screwed everything all up. so i take it to get the front in checked out and they tell me its going to be $500 for inner and outter tie rods. after i get this fixed im wanting to lower it but will it mess up the tie rods again by lowering it? the guy at the shop said it will mess it up and i would have to spend $1000 to get it right. im just going to buy lowering springs because the stock struts i have only have 5000 miles on them.
Re: lowering problems
guy is lying. If you really need inner and out tie rods, they are easy to do yourself. If you cant, find another shop and get a second opinion on just replacing them. When you change the height of the car the alignment changes so you will need to get it re aligned if you change the height. But it will not damage anything by doing so.
Same thing here, I recently got a 93 Civic Hatch and the guy that had it before me cut and heated the springs. Total jacked everything up and I had to replace the tie rods and shocks. But it is easy to do yourself so that is something to consider.
so if i just get these tein lowering springs then will it mess anything up? my struts are in perfect conditon.
http://www.andysautosport.com/honda/..._springs/tein/
TH22A1
12-04-2009 05:25 PM
suspendedHatch
03-28-2004 11:37 AM
