Clutch noises and not functioning correctly.
I went out today to drive my car and get some food, on the way back I got on it and when i tried to shift into 2nd from 1st it got stuck, now i know everyone misses shifts but i didn't miss it, it went in and got stuck half way through and wouldn't go in and started grinding. So i pushed the clutch in and changed gears, and it changed fine then the pedal started feeling softer. It acted like the clutch wasn't there. It went from feeling brand new to like it was old and gone. Now i can't shift gears so I get it into 3rd and drove home on that. I get into my garage let it sit for a while and try the clutch again and when i try to push the clutch in with it disengaged it makes this noise: http://youtu.be/jYhqSZoEPi4
Is it the pilot bearing? TOB? pressure plate? i ordered a new clutch and flywheel, as well as a new slave cylinder. I think mine might be leaking.
Re: Clutch noises and not functioning correctly.
alright thats what i was thinking, when i press down the pedal it does nothing but when i move the shifter into gear it starts making that noise and then if i pull it out of gear and into neutral with it pressed in it still makes the noise and when i release the pedal it stops.
ls2poweredgoat
04-24-2009 02:24 PM
