What would cause this starting problem?
Old Aug 2, 2011 | 10:42 AM
Pwnmeister's Avatar
Default What would cause this starting problem?
So whenever I try to start my car, it would take couple cranks to start. I would have to hold the key for like couple seconds, it makes this "juk juk juk..." sound when i'm holding the key and then the car would start up after that couple seconds.
If I try to start the car again like an hour after turning it off, it'll start in an instant. Once the car has been off for too long, it'll take couple cranks again to start the car.
What could be causing this?
Maybe starter, battery, spark plugs?
thanks
Old Aug 2, 2011 | 10:47 AM
TheMechanic84's Avatar
Default Re: What would cost this starting problem?
fuel pressure
Old Aug 2, 2011 | 10:59 AM
Wrona's Avatar
is it a 96-00 civic? and is your tank usually at 1/4? yeah if that than theres your problem
Old Aug 2, 2011 | 11:02 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: What would cause this starting problem?
When it doesn't start right away watch to see if the check light comes on for a second or two and then cuts off (fuel pump priming indicator). If it doesn't then you may have a main relay issue.
Old Aug 2, 2011 | 12:17 PM
Pwnmeister's Avatar
yes it is a 96 civic and the starting problem happens despite the amount of gas i have.
I will pay attention to it when i start it later but i dont remember seeing any light going on as i hold the key to start the car. If it's a main relay issue. How do i go about fixing that?
Old Aug 2, 2011 | 12:23 PM
Pwnmeister's Avatar
So the starter is fine?
Old Aug 2, 2011 | 12:41 PM
motegicivic's Avatar
i wonder if you have a crank sensor problem.
bobmugen
Aug 22, 2012 01:27 AM
moleodonuts
Aug 6, 2004 11:21 PM
93egsi
11
Jun 18, 2004 05:37 AM
N1NjA TuRtLE
19
Oct 11, 2002 07:41 AM
