94 CIVIC EX WONT START
My 1994 honda civic ex wont turn on. It was working fine until lunhc break at work for me today, and it just would turn on at all. The radio/fans come on, but the engine wont crank. When I put the car into the ignition and try tostart the car, the inside dies and doesnt start. I had this problem long time ago, where it was an alarm in my car that was killing the ignition. But I had a mechanic take it out, and im not sure but its acting the same way it did before. Car was working 100% before this. Any suggestions I should try? I whacked the starter already thinking it might have worked, but it didnt.
Re: 94 CIVIC EX WONT START
do you hear the fuel pump clic for 2 seconds when you turn your ignition ON II
if not could be a bad main relay
also check if you are getting spark but you said its not turning over since 92-95 civics have bad main relays thats what im betting on
I really think its the alarm thing in my system, he said that my alarm system killed the ignition. I want to check the fuses aswell, any diagrams of ignition wiring? I want to just bypass the alarm I guess. and make sure the ignition is hook up straight.
if the car worked after the alarm was pulled out why would it cause it to die now? and you didnt answer the question if the fuel pump primes.. .
B16B Four Door
Audio / Security / Video
09-19-2015 06:23 PM
marQues24
11-27-2012 10:59 AM
TurboEK9Coupe
01-17-2009 07:03 AM
