Sea foam ?
Sea foam ?
Do you guys recommend using seafoam in the motor to clean it out some of the carbon etc..its a d16z6 with only 82xxx miles..i did search online but i only came across threads that are over 1 yr old
Re: Sea foam ?
It should be safe to add Seafoam to the gas tank and through the brake booster vacuum hose. For the latter, replace the spark plugs afterwards. Adding to the crankcase is a matter of choice, but I think that it's also probably okay for an engine with 80K miles as long as you follow the directions.
Re: Sea foam ?
I know 30-40 people personally that have used seafoam to clean their engines, never did any harm.
Most do it through the brake booster vac hose, and then watch the huge white smoke clouds----and believe they just cleaned their engine out..
Im not convinced it does anything--- although 90% of the people I know say they feel an immediate difference.
Id say try it.....and see how it goes. As far as I know, its completely safe (as long as you follow the directions)
Re: Sea foam ?
BG44K is the best stuff you can have in your system... seafoam is what 8 bucks or something BG is 25 bucks a can... I have seen Bg44k Actually make a car pass Emissions aloneand increase mpg in a 20 year old V8
Also BG backs there product so if it harms your engine they correct it... Sea foam dosent
Troll??
Troll??
Re: Sea foam ?
BG44K is what was recommended to me by my local Honda dealership. I didn't buy it there because I was skeptical but I've used it many times over the years and like the results.
Re: Sea foam ?
I'll tell you yes yes yes. Seafoam is jesus juice for motors, does an amazing job. Especially if you do it right and put it on a dripper and let idle for 30 min.
Re: Sea foam ?
just to add a bit more to the list of replies...
when used properly, Sea Foam can work. there was no appreciable effect in my civic, but my wife's accord was like a different car after running it through. it must have been dirtier.
milkwasabadidea
08-29-2011 05:14 PM
Discontained
10-25-2006 03:16 PM
