H22A EK hatch.
Old 08-04-2011, 09:51 PM
lolchrisland's Avatar
Default H22A EK hatch.
I am going to be putting a H22A into a EK hatch. Just wondering what what ecu would I be better off with? And what engine wiring harness should I use? Or does that matter as long as it's VTEC harness? I'm still learning and I intend to learn a lot from this.. so all the helpful info I could get would be great.
Old 08-04-2011, 11:22 PM
NotAJDMFanBoy's Avatar
Default Re: H22A EK hatch.
You need the EK hatch wiring harness. Just extend the wires, add wires for IABs, trim the injectors so your clips will fit on, it's pretty simple. And you need an OBD2 H22A ECU, or convert to OBD1 and run a chipped ECU
Old 08-05-2011, 04:37 AM
Ek Forever y0!
Libertariat's Avatar
I would recommend getting a p28 with an h22 basemap from a reputable vendor like phearable or something.
I hope you're doing an h2b
Old 08-05-2011, 08:30 AM
DSMAddicted's Avatar
Turbogixxer is great too. He chipped and programmed my P28 and will hopefully be tuning my car soon. Look him up on this Forum, he's also on Facebook (Turbogixxer tuning).
Good luck!
Old 08-05-2011, 08:58 AM
Okay great. Thanks. Now I have a question about injectors. Peak and hold vs saturated. Peak and hold require a resistor box.. correct? Are there certain resistor boxes for certain injectors or can it be any resistor box? I've looked everywhere and cannot find the answer to that question so I can only assume it's a dumb question. xD But I'd still like to know..
ryanlegros
12-31-2012 06:11 AM
ekhatch66
08-29-2008 09:58 AM
h22hatch88
02-27-2008 01:35 AM
yonkers062986
08-09-2007 06:40 PM
wbb6
04-09-2002 05:11 PM
Quick Reply: H22A EK hatch.
