just bought shell Now to plan build
Pictures soon
97 civic project(deep sleep) NEW YORK
Goals: flat blacked out DD with 350+whp
Base budget:NO COSMETICS $4000
budget tracking
Shell:$1000
power plant as of now sohc broken rod.
any suggestions on best bang for your buck swap to start with? will work on the power after i get the car up and running.
budget tracking
Shell:$1000
Re: just bought shell Now to plan build
Your d series is another man's type R... Seriously... Everyone that comes into this thread will recommend something different. Do your homework and build it however the hell YOU want it. Don't ask us to plan your build for you.
he doesn't have a D series he said he bought a shell... that has a thrown rod
I wouldnt have paid a grand for that, but thats just me. Im aware that it has a thrown rod... I'm just saying... Everyone has their opinions on engines, so you shouldnt take someones opinion to realize that its not what you expected....
Good luck to you, if you want power, the cheapest way is an h series with boost. K series will cost you about 6-8K+ before boost. Around here you can get a complete h series swap for under 2k. Its a little heavier but you do have a four door. If you piece your parts together price wise i bet you could have a boosted h-series that meets your hp goals for around 4k.
OK the choice has been made platform one will be a boosted D series.
ECONO-power
now to find a donor motor
what would be a good price range to stay in for a donor? im in newyork
and what engine code would be best for boost.
i have heard that the stock rods are limited and a 440cc injector will be reaching top duty cycle for the 300 mark.
im looking to possible build the block thats in the car if the damage inside isnt to bad.
ECONO-power
D16Y8
1.6L 16-Valve SOHC VTEC Also available in New Zealand under the code D16Y6
Found in: 1996–1997 Honda Del Sol Si (US)
1996–2000 Honda Civic EX (US, UK)
1996–2000 Honda Civic Si (Canada) Displacement – 1,590 cc
Redline – 6,800 rpm
Rev Limit – 7,200 rpm
ECU Code – P2P
Piston Code - P2P
Vtec Switch over – 5,600 rpm
127 hp (95 kW) at 6,600 rpm
107 lb·ft (145 N·m) at 5,500 rpm
Compression – 9.6:1
ok im told this is the specs more intel from the previous owner .He is now telling me that the owner before him did a swap. something about a mini me swap with a del-sol motor? researching now not sure wth hes talking about.
will provide engine pictures and block codes asap
Redline – 6,800 rpm
ECU Code – P2P
Piston Code - P2P
Compression – 9.6:1
ok more info from previous owner hes telling me it was the block that was changed and the engine code is d16a... he hasnt given me a numeric to the (A) engine code yet. im supposed to be picking this car up this coming weekend wondering if its worth my time now? i was gonna go with the 1000 asking price because i thought i had found the one untouched honda in my area.... guess i was wrong im awaiting engine pictures and code pictures also.
