d16z6 AC stopped working :(
got a 93 sedan dx with a d16z6 swapped into it i live in texas and its hot as **** lol it was working just fine last nite then suddenly my cars rpm raised up to 2k at idle with the ac on and isnt blowing cold anymore. what should i try and check?
Re: d16z6 AC stopped working :(
You need to hook up a guage to your low and high pressure lines and see what the readings are at idle with the ac on.
If you have a leak and lose your freon the compressor knows the change in pressure and won't come on. Hence your idle will go up. Hopefully you just have a bad o-ring in the schrader valve (cheap fix). Try to get it fixed ASAP before moisture gets in your system.
