b20 swap help!!!!!
b20 swap help!!!!!
so i have a 2000 civic ex and i want to swap it out with a b20 my engine harness is also chopped up and no good.
what engine harness and ecu can i use? PLEASE HELP!!!!
Re: b20 swap help!!!!!
read this... it quicker if u just google it
http://www.b20vtec.com/forums/b-seri...-harnesss.html
Retired Moderator
u can use another EJ8 harness, but the distrib and a sensor here and there will need to be re-wired. also a ECU harness will need to be used.
Theres also distrib harnesses that are plug and play to save you if your wiring/search challenged.
http://www.velocityshop.com/categori...lated_117.html
use the stock civic harness then buy a crv ecu it should all plug and play. you will have the extra wires to wire a vtec head on if u want to int he future. the crv and your civic harness are identical other then you civic have vtec.
