EG43 D15B2 (DPFI) - Coolant bleeding procedure?
Hi folks,
I have a 94' Civic with a DPFI D15B2 (European). The idle is surging (correct term?) 50-300 rpm above the desired idle when warm. I suspect the EACV needs cleaning, okay. How do I go about bleeding the coolant after cleaning the EACV? - What's the correct procedure for this ol' fella? :-)
Re: EG43 D15B2 (DPFI) - Coolant bleeding procedure?
im pretty sure theres a bleeder bolt next to the Upper rad hose where it goes into the head open that up run the car keep adding coolant till you see no bubbles
