y7/z6 mini me jumping timing
Everytime I rotate the belt after setting the timing the belt slips and moves the timing off a tooth at a time. Any help? Im also using the z6 cam gear, z6 belt and z6 water pump. Belt is extra tight.
Re: y7/z6 mini me jumping timing
Yes im using a y7 block. Taking the water pump off now. Thanks. Will update if problem is solved.
Technical Hero
Yeah what water pump were you using?
From another thread:
Z1/Z6 water pump is 19 teeth approx 55mm OD
B2/A6 water pump is 19 teeth approx 54mm OD
Y7/Y8 water pump is 19 teeth approx 56mm OD
YumVTEC
09-27-2004 11:54 AM
